DunbarLtd
Thread starter- Joined
- Nov 8, 2016
- 357
88 bayliner Force 85hp with 17p prop.
Runs fine and shift cables are in good working condition and "adjusted" as much as I know how to.
Last trip out I was hearing some odd clanking sound when i shifted gears into forward. It sounds like if you tapped a big screwdriver onto a prop blade. Like that "DING" sound. I did not hear it in reverse IIRC. Seems like its not adjusted properly.
When I trim the outboard up and rest it on its support bar and spin the prop i can feel the clutch dog rubbing on the gearset just ever so slightly. Trimmed down - no rubbing
Prop looks fine. No play on the prop as the nut is torqued well. The boat shifts into gear just fine.
Perhaps the shift cables need fine tuning and is cause of the noise?
Anyone have any idea whats going on and what to check/test?
