Trophy 2006
- Joined
- Apr 5, 2021
- 4
Hey everyone I hope someone can help diagnose the issue. I purchased the Boat in Maryland and I had compression tests done on both engines. The mechanics at the shop in Maryland said they changed the oil and when I got the boat to Colorado oil was leaking through the small hole on the lower unit. I took the boat to a mechanic in Colorado and the oil had been top filled and over filled and not changed. The mechanic in Colorado changed all the gear oil and engine oil. I took the boat out and the oil pressure alarm went off. I pulled the cowling off and oil was spiting through dip stick tube. Does this engine have a PCV valve that could be sticking. The mechanic has the boat again and hasnt had time to look at it. Please help
