Honda bf20 not turning over.
Jayzc66
Just did an oil change and Gear oil change the other day and I had put boat in the water to start up. But it is solid frozen. Can't start it up. I haven't pulled spark plugs yet or tried moving flywheel. Maybe I can try that? Idk.
Jayzc66
ahicks
Tell me about "solid frozen" please?
Does that mean that the starter rope will not pull out?
Can you turn the prop?
Does it seem to be shifting OK?
Jayzc66
Yes that's what I meant. Like the flywheel is stuck. I can turn the prop and the shifter I did notice that it didn't work going in reverse shift, just neutral and forward.
MattFL
My guess is you either over filled the oil or transported it on the wrong side and now the cylinder is full of oil. Remove the spark plug, pull the rope and see what comes out. Pull the rope a few times to get most of the oil out, double check the engine oil level, put the spark plug back in and fire it up. No permanent damage done, just a mess.
Jayzc66
Hey thanks Matt! I really appreciate the help! It's working now! :)
Jayzc66
Yeah I over filled the oil and transportation was the thing. Ty!
