halsteadmorris
Thread starter- Joined
- Mar 10, 2021
- 41
Firstly: 1958 18hp Evinrude Fastwin model 15024
I purchased this motor close to a month ago and have been having trouble keeping it running. After waiting on a clear fuel line I have discovered that the motor does not pull gas in at all. Unless gas is directly pumped into the bowl it will not get fuel. I’m assuming this is due to no vacuum.
I noticed what looks to be a poorly made gasket on the carb. I’ve ordered a new one. Could that be cause? The seller claims to have gone through the gas can and it seems to check out but I may go through that as well.
I’m waiting on a carb kit to ship in. Is there anytime I should be checking in the mean time? Is there a reliable way to test for a vacuum leak so o can confirm that’s my issue?
I’ve attached a picture of the suspect gasket as well as the fuel that is still on the line after I disconnected it while running to see if it was getting fuel.
