Grinding noise
Status
Not open for further replies.
Szaszing
Hello all,
I took my boat out today for the first time since last October.. it’s a sea ray with a mercrusier 5.7 alpha one.
when pulling out of the canal I noticed an annoying grinding type noise when moving and again at idle. When in neutral it seems louder then when in gear, and also sounds like it’s over revving.. the noise also gets louder when turning the wheel hard left or hard right
The noise may have a little gurgling too.
Any thoughts?? Thank you
Most likely gimbal bearing and/or U joints. When was the last time the drive was removed, inspected and alignment checked?
Szaszing
The beginning of last season. It was only ran about 60 hours last season and sounded great right before it was winterized.
It sounded fine except for one short time of a slight higher pitch screech or something.
Check the lube level at the drive vent pulp, then pull the drive, I think its their.
Plug, drive vent plug
The plug on the top section of the drive which is removed when the drive is being filled
I pulled the boat today and do not hear the noise out of water
Put your fingers inside the gimble bearing and rotate it. See if it feels a smooth as silk with no roughness
Szaszing
The one circled ?
Szaszing
Anyone see anything wrong from these photos ?
Status
