gas line for 2strokes
jorgelazo
good morning everyone
I have in my boat two engines 1 suzuki 225hp 4strokes and 1 suzuki 40hp 2strokes, someone knows if there is a kit to place the direct fuel line to the 2strokes engine but that on the way I can add the 2T oil, to avoid being carrying a tank 6 gallon extra on the deck and only use the main 120 gallon tank, thanks for your comments
jworks
It sounds like you are wanting to use the 120 gal tank to run the 40 hp engine to avoid carrying an extra tank on deck. I don't know how you plan to add the oil to the fuel going to the 40 hp but I'd think you would need an oil injector on the 40 hp to do that. And, that would require an oil reservoir too.
GA_Boater
Welcome aboard.
Is the small motor oil injected? If not, the only way is with portable tank. No kit exists for what you want to do.
