Mcfltfyter
- Joined
- Apr 9, 2021
- 119
I bought a 2007 tahoe 5.0 alpha 1 gen 2. I've been going over its issues and there were a few wires loose when I pulled the instrument panel. The blower didn't work and I found both blower wires off the switch along with the hot wire to the ignition. I can't get power from any ignition switch wire, so I'm thinking he was using the blower power for the ignition and the wire was so tight it came off when I pulled the cluster back.
The ignition power goes into a loom and disappears to the stern somewhere. Every hot wire I check at the battery, starter and everything I can find is hot. Now even if I use the blower power it won't crank and something clicks at the engine, but I can't verify it is the starter solenoid until I can find an extra hand.
Any thoughts or ideas would be appreciated
