healey8390
Thread starter- Joined
- Nov 19, 2010
- 217
86' 110, getting a lean sneeze and puff of smoke near a bypass cover. I'm pretty sure it's the crankcase as it's the same exact area that leaked the first time. Reference this thread if needed https://forums.iboats.com/threads/leaking-case-halves-crankcase.741260/#post-5629912
When I did the job again I noticed a glob of sealant that wedged the block. So I was hoping that this time it was fine. I cleaned the ever loving you know what out of it. Used primer, torque wrench/sequence. We'll I'm in the same boat again.
I'm wondering why it's leaking and in the same area. The original teardown before it leaked the first time was because the engine overheated. But it was on the other bank, port, and it's the starboard side that I'm having the problem with.
My question is, aside from getting another powerhead and/or just parting out this engine, is that can I get an upper case half or whatever it's called? The smaller side? Probably a hard question to answer but I'm assuming if there is warpage it will be on the skinny side not the block side??
Can I sand down the case halves? If I use 1000 grit on glass with a figure 8? Or is it time to give up on this motor?
