No spark
Robbie75
Hi guys need some help, I have a mercruiser 5.7 v8 350 with the thunderbolt ignition.
Had to completely rebuild the engine as it was out of the boat. It is now built and I am trying to get it started.
No spark at the plugs, the neutral cut out switch is in an open circuit but when I put the ignition module ground on the safety switch closes. It also does it when I ground the dizzy.
Any ideas would be greatly appreciated.
Bt Doctur
Robbie75
The black wire from the ignition module when I put it to ground it closes the circuit on the neutral safety switch
Bt Doctur
The thunderbolt has 5 leads. black ground, purple and grey to coil, White/W red stripe and White/W green stripe to dist. These have nothing to do with the neutral safety switch that is in the control box to prevent starting in gear.
Bt Doctur
can you explain what is happening when trying to start the motor
kenny nunez
I wonder if he is confusing the shift interrupter with the neutral switch in the control box.
Robbie75
Hi I have everything connected correctly white red, white green between the dizzy and ignition module. Also the white green from the safety switch am I correct in saying the safety switch is a normally open contact then when closed grounds the ignition module which prevents sparking.
When I Bell across the safety switch it is open circuit but as soon as I ground the black core from the dizzy or the black core from the ignition module the safety switch becomes a closed circuit there for the ground travelling down the white green from somewhere else. This is what I am guessing, everything turns over fine just no spark
nola mike
Yes, but it isn't a safety switch. It's the shift interrupt switch, which normally grounds out the ignition for a moment to allow you to shift gears. There's a good TB troubleshooting article in the adults only sticky at the top of the forum page.
Ayuh,..... Or in the link in my signature,....
achris
More fish than mountain goat
... There's a good TB troubleshooting article in the adults only sticky at the top of the forum page.
This one?
Chris......
nola mike
This one?
Chris......
No, no, I think I remember a good one at some point 😙
