iboaterlurker5
Thread starter- Joined
- Apr 2, 2021
- 49
Local gas station has 90 unleaded ethanol free gas and 93 unleaded with ethanol gas.
Old Ford 460 marine carb engine. RPM Max: 5000 RPM, Compression ratio 8.35:1, 160F degree thermostat, elevation around ~500 ft, ambient temps around 80-100F. Manual says I should run 93.5 leaded gasoline.
For this low compression that seems unnecessary and I would like to run ethanol free if at possible for the carbs and fuel lines sake. No knock sensor on the engine (carb), so I obviously don't want to ping.
Run 90 ethanol free or 93 with ethanol?
