You need a few tools but the drive shaft with gears comes out the front.
The yoke and gears are removed to gain access to the seal
Then everything is put back together IF "everything is within spec"
Then the preload is measured to ensure the nut is not over tightened
In short you need manual 11 to even begin, not counting the tools needed to remove and replace
