Merc engine overheated & shut off. Lost oil into bilge. Smoke.
HumbleMonk
1995 Searay Sundancer 300
HID: SERT7493A595
Serial: 0f490921 (as far as I can tell)
1995 Merc MIE 5.7 Litre
Onset: Was running at high rpm for a few minutes, boat would not plane.
The engine shut off and smoke came from engine compartment. No audible changes in the engine except the loss of power. Engine appears to have lost about a quart of oil into the bilge.
I have not attempted to restart the engine. Should I?
Has anyone had this similar problem?
I'm looking for help identifying possible causes and solutions.
Thanks in advance!
Bt Doctur
Not enough motor for the 30 foot boat
The last one I worked on with that symptom had holed a piston ,had severe detonation,and blew the oil out the dipstick and pvc fitting
Ayuh,..... Welcome Aboard,...... Have ya checked the oil level to see how much was lost,..??
Do a compression test to see what's goin' on,.....
HumbleMonk
Yes, oil level is still within threshold. I’m investigating further.
HumbleMonk
Heh, well first time encountering burnt transmission fluid. It’s not oil in the bilge, it’s transmission fluid.
Ayuh,...... As in red Atf fluid,..??
That's somethings used in the P/S systems, or in trim pumps,.....
smoke and high RPM's indicate the coupler is toast.
you have been pulling the drive every year and checking alignment?
