8hp Mercury revs up, then stalls! See video
henryst
My year 2000 8hp Mercury starts right up on the first pull. But then, as it is idling, it begins to rev up on its own, then coughs/misses and continues to idle. Eventually, it will sputter out and die.
I thought it was definitely a carburetor/air leak/gas tank problem, but I've cleaned the carburetor thoroughly twice, tried a different gas tank and hose, and searched thoroughly for leaks. The spark is good on both cylinders.
Here is a video of the problem (listen with sound). Thanks in advance for any help!
**if you can't see the video, try to download it– worked for me**
View attachment IMG_2635 2.MOV
henryst
What happens if you pump the fuel ball while that is happening?
Good question... sometimes that helps, sometimes it doesn't. I thought it was a fuel pump problem for a while, but switched out all hoses/tank with no change.
