76SeaRay
- Joined
- Aug 24, 2017
- 1,071
Do you run the stringer right up against the transom wood, fillet and tab that or do you need to put peanut butter between the stringer and transom wood to bed it?
Also, is it better or easier to lay a bead of peanut butter and then set the stringer into that or put in small foam spacers then "squeegy" the peanut butter under the stringer? Looking for the best result.
Thanks...
Thanks...
