Kola16
Thread starter- Joined
- Jun 23, 2019
- 229
Hello all. My Mercruiser 260 GM 5.7L I/O with the MC-1 Drive sounds like it is missing, or starving for fuel at higher RPMs (4000+). It does it when already on plane, and/or out of the hole. It is happy as a clam at idling and cruising speeds (750-3500 RPMs).
Here is all the back info:
- All parts and engine have less than 75 hours on them over 5 years from the rebuild.
- I just put a well rebuilt Edelbrock 1409 on it (5/1) with the adapter plate. I had a Rochester Quadrajet on it, but it was always giving me fits. The person who rebuilt the Quadrajet did a very poor job. The Quadrajet also had the problem it is having now.
- It has a Pertronix electronic ignition built from the old original distributor from the 1979 block. The Pertronix was added 5 years ago with the new rebuild.
- The ignition coil is new and I tried another one just to make sure. Still the same results.
- I will be changing the spark plugs today. Hopefully changing the plug wires soon once I find the right part numbers.
- Rotor is new 2 years ago now. I'll be replacing that any day.
- Cap is probably 5 years old with the new rebuild so I should replace that too any day.
- I checked my fuel line from the tank pickup to the carb and all is clean. Even ran it on a 6 gallon plastic tank and still the same missing sound. Checked the vent line too. I run non-ethanol gas too, and there was no water in the fuel-water separator.
-The boat sits on a trailer, no bottom growth to worry about or anything.
-The problem has been hit and miss for 2 years now and I haven't been able to pin it.
-It does not always do it. Usually it happens after being on the water for more than 20 minutes or so...which is very frustrating because it wont happen for many hours sometimes, and I will think it is gone from whatever I did, but then all of the sudden........IT'S BACK!!!
Thanks for any help or ideas!
- Could it be the mixture screws on the carb? I never adjusted those on the new carb, but I had the same missing with the old carb. I did not play with the mixture screws with the Edelbrock since I have never done it before, but I could learn how to do that...
- Could it be the old distributor body conversion to electronic ignition?
- Could it be the mechanical fuel pump going out? I took it apart and all of the rubber looked good, no frays...
- Could it be me not changing the wires, cap, plugs etc.? I will be doing that ASAP and will update once complete...
