Friendliest_catch
Thread starter- Joined
- May 9, 2021
- 29
Good afternoon !
Have a 1985 Marlin with an OMC chevy 3.8 v6 with a cracked starboard manifold. Only one crack and only on that side.
I have found plenty of replacement new manifolds for the 4.3 v6 but I can't find any in stock for the 3.8 . I understand that I may have to do a mid riser conversion but also have had little luck putting a kit together that has all the parts.
Any manufacturers make 4.3 manifolds confirmed to fit 3.8? Will the Sierra manifolds for the 4.3 fit no problem?
This is one example I have seen on ebay but I'd need the riser and associated plumbing to go with it.
Am I safe to pack the current crack with high temp rtv after terminating crack with a small drill bit while I wait for the new parts to come in ?
First I/O motor boat I have owned and I'm learning about some of the difficulty in finding old boat parts.
The engine runs great and has good compression between 133-140 on all cylinders. 5 inch long hairline crack from fore to aft on the bottom of the manifold . Some rust streaking . No visible leak when the boat is running from what I've seen so far.
After looking around the forum and online for a few hours and not finding an updated answer to my questions I wanted to post here. Really hope someone can point me In the right direction !
Thanks for the help
Thanks for the help
