Ok, so I was out last weekend and out of nowhere the outboard quit on me when I slowed down, getting close to shore. Pulling it over I have no joy. If I prime it, the motor will start every time, but then die a second later. I then figured out that if I prime it, and then gun the throttle, it will take off, and work great from about 1/2 throttle to full throttle.
After an involentary very fast trip home I pulled the carb apart expecting to find the idle circuit clogged.
What I found was a pristine carb with the center brass tube broken off down deep in the emulsion tube (I think thats what its called).
Question 1. Is this replaceable? I'm thinking no, because I do not see it on any parts breakdown.
Question 2. Is this even the right carb for my outboard? My model is J25REEB, yet the J25R carb does not look like this in the parts breakdowns. Mine appears to be a 25JR carb judging by the pictures.
If I need to buy a new carb, I want to make sure it is correct for my motor. (but I guess you could argue that this one was working fine until that tube broke. I still have no idea how that is even possible).
