1995 mercury 125 hp og039265 is what I have, the tilt is a single ram with a three wire motor. I recently resealed the piston and cylinder topped it off with transmission fluid and it worked just fine two previous times out fishing, however the last time out when ever I trim down the motor bounces down not a smooth movement " much like when bouncing a banquet ball down to no bounce " jeje cant think of another way to explain it. In short it bounces all the way down. While in the water I'm able to trim the motor just fine the tilt is holding up ok, but out of the water the bouncing down of the engine shake's the hole boat. any advice will be very much appreciated. thanks !
