Dennis197SD
Thread starter- Joined
- Aug 15, 2019
- 52
I recently installed a remanufactured 4.3 in my 06 bayliner 197sd... motor came from gearheads with a no fault warranty.. while testing on water after about 30 min I was running at 2800rpm and I noticed a slight change/ light hesitation in the way it was running as well as some light smoke coming from the valve cover hoses.... came back to an idle and the smoke stopped...I continued testing but noticed a knocking noise now but only at certain rpm ranges...I ran for an additional 1.5 hours with no change in noise...i moved the distributor to see if that affected the noise and it did not.. I also removed the lower unit in the driveway and ran to see if the noise went away but there was no change. Im gonna upload some videos and would like to see what you guys think....is this an internal engine issue? Is it possible it's something else? Any ideas would be appreciated. Thanks
