jonny rotten
- Joined
- Jan 8, 2012
- 349
I replaced the lower shifter cable last year. Immediately after, shifting from forward to neutral would bind up. To try to explain it, it would be like a shock absorber or pushing against an air pocket where it wanted to push back almost bouncy feeling. Like trying to push the inner cable but something was holding it up. Accelerating and decelerating was smooth only happens from idling in gear to neutral
The strange thing is it would only happen occasionally. Usually at the ramp with other boats around giving me a heart attack
Other times (most times almost always) it shifts perfectly smooth. Forward, reverse, in and out of gear...everything fine.
I never had this problem with the old shift cable. The reason for changing it was because it was stiff accelerating which I figured it was rusting on the inside of the cable. Which the new cable fixed.....but never had binding issues like this.
I went through the adjustment procedures on the barrel and think I got it right after I installed the cable. No stalling issues
The shifter shoe moves freely and so does the shifter lever with the bearing on it. I believe the shift interrupter is working correctly. It stalls when I push the wheel in
Before I pull the outdrive off and start messing with things is there something I should look for to see if it's incorrect so I know I corrected the problem?
What would cause intermittent binding to the point something feels like it's going to snap when I forcefully yank it into neural as I'm heading for another boat at the dock?
It may clunk when it finally shifts but I can't remember...possibly not
Could it be the way the cable is routed? I used the old cable as guide but had some issues. It could be routed "not perfect "
