HorizonblueDK
Thread starter- Joined
- May 27, 2010
- 355
I have converted my 470 into a 4 barrel carb, since I had a donor motor with all the parts needed. I rebuild the carb, took all the time in the world to make sure everything was right, cleaned and blew out every passage inside, installed bushings on the primary shaft. But something is wrong, I'm not sure it's the carb...On the first test run on the ocean, in fired up and ran well. I waited until the temp was ok, before I started to accelerate. It went on the plane and I ran at 3000 rpm. After maybe 5 seconds, the engine started bogging-sounds like it was running on 3 cylinders, so I backed down. Trying to accelerate again and it did so, without backfiring, but still only 3 cylinders. So I humped back to the marina, on 3 cylinder most of the time, sometimes 4. It stayed alive, even when docking, on 3 cylinders. So after a break, I started it and it ran fine, took a little trip, but same story again. Before the test run, I replaced the spark plugs, since there was two different types in it.... I had some NGK BR6FS laying around, not new, but the looked ok, so I re-gapped them to 35 thousands, maybe a little more. Last year the engine ran fine, with the two barrel carb (and different spark plugs). Compression is around 120-140 psi on all cylinders. I suspect that I have an ignition problem, but I would like to hear opinions.
