Alumacraft Year and Specifications
Status
Not open for further replies.
Yardwork
Finished the restoration and ready to go...thank y'all for all the encouragement and information. This 1959 Alumacraft FD is ready to carry a new generation of grandkids.
Yardwork
The project is complete! She ran great, launches and loaded easily...going to be a good boat.
Robert Minck
I just purchased a 1973 Alumacraft FD, 14', and am in the process of restoring the boat--replacing the transom, cleaning the boat inside and out, and sealing several small leaks in the bow at the keel. Your discussion above has been helpful. Thanks.
Yardwork
What insurance value should I place on the hull, motor and trailer?
Yardwork
So, I have received the answer to the date of manufacturing today. Thank you AlumaCraft. What I was thinking was a 1959, which the DMV lists as a 1960 is actually a 1956. Good to know.
Now how do I get a manufactures capacity plate replacement?
Robert Minck
I requested similar info for my '73 weeks ago...no response to date. Not very responsive support.
jbcurt00
Garzon Studios online can replicate a capacity plate if you have a good pix of 1. Then you apply there vinyl to an aluminum plate you source/fab on your own.
If you dont have a good reference pix Garzon has several standard plate designs to choose from.
If you have a trophy shop close or a print shop, ask if they can sublimate an aluminum plate for you. Its a print direct to aluminum process, they too need a good reference plate.
Had several dozen plates made for a vintage boat group I was active with.
Look great and arent expensive, <$20. May have to pay a graphic artist to produce the image if you dont have a good 1 to provide. More the $20, probably less then $100 though
Yardwork
I emailed him and asked for a quote...thanks!
Kyman53
Hi I am redoing a 89 Alumnacraft 16 ft with a 1996 40 hp Mercury Force Mariner 2 cycle outboard with power trim & tilt. Where could I find the decal of weight limit? Also do you thank a 50hp outboard would be to much for this flat bottom boat?
Thank you very much. Kyman53 to bad want see 53 again turning 55 31 of July lol.
jbcurt00
Start a topic about your Alumacraft
Asking questions about yours here in someone elses is considered a hijack and discouraged
Kyman53
opps sorry thought you asked in area of same subject please help ok? again sorry
MstrDan
I find this thread very helpful. I am in the process of doing a very similar project. The pics and wood types are so appreciated. I am thinking on the same lines as this. Thanks
Status
