It’s a 1988 v20 mercruiser alpha 1 I/O 1 owner just bought it Was well maintained out in water twice stuck twice water in gas then after we cleared it it wouldn’t come out of throttle into gear
Ayuh,..... Is the controller stuck in throttle only,..?? if so, fix the controller,...
Is the forward cable from the control to the shift plate by the motor workin',..??
Can you shift the drive with the lower shift cable removed from the shift plate, manually,..??
