UPTHERIVER
Thread starter- Joined
- May 28, 2021
- 1
Hello all.
I have a 1988 OMC 4.3. I had just replaced the motor. Prior to removing it from the donor boat it test ran it for over a hour. And it ran great. No issues other than the exhaust manifold did have a crack, and was leaking into the bilge area. The oil looked fine. ( freshly changed at the start)
Now I installed it in my boat, and lake tested it for 20 minutes. And I have over a quart of water in the oil.
I replaced the exhaust manifolds with the ones off my other motor that were good.
The only difference between. The engines is my old one was a 2 barrel, and the replacement engine is a 4 barrel.
That should not matter correct?
They looked the same. Other than the markings. Old ones say 4.3 liter. Replacement engines said 4.3L 4 valve on the manifolds.
I did a pressure test on the engine cooling system and it slowly leaks down.
We did a leakdown test of each cylinder and all passed.
What are your thoughts?
