toooldtofishsoshootem
Thread starter- Joined
- Sep 19, 2010
- 33
Hello all,
Motor worked fine last season, started up with 2 pulls today after sitting all winter. Ran like a champ. however, flow from pee hole was light to moderate at idle, but eventually when run at higher speeds (in barrel) stream sputtered, then ran ok, then sputter and water temp was very hot. About 30 seconds later either steam or exhaust (I guess I mixed the first gas batch a little rich) came out in a regular pulse pattern. Subsequent re starts would produce intermittent water stream then steam/smoke-exhaust. Reamed out pea hole tube about 8" back to exhaust plate on side of motor but no change in pattern. Before I figure out how to drop the lower unit to check pump, or remove side (exhaust?) plate on power head where the pee hole tube originates, I thought is might be best to check to see what order I should start checking and what area I should start first. Lower unit was well under water when tested, and no external blockages were seen at the water intake. Assuming some disassembly is required, would like to have a detailed service manual and parts diagrams/torque specs etc as my "crutch". I just (2 years ago) stuck $200 for a ignition switch module (fenolic?) and $50 of other parts plus all new ignition wiring now hate to see that go to waste without at least attempting to getting it back up and running as it should.
Any help would be appreciated.
thanks.
thanks.
