chopper_bob
- Joined
- Aug 24, 2020
- 30
Hello,
Apologize moderators, I started another thread on my issue as my reason for posting/title changed after further troubleshooting.
350merc B3, on 2013 Monterey 244fs, only 150 hrs, well maintained.
My question is, and it should be pretty simple to find an answer, guardian mode kicks in ALONG WITH CONSTANT HORN, with no explanation as to why from boat. Ive had it kick in 2x before, but the gauge told me afterwards (once for low block pressure other for low outdrive oil) why it tripped the alarm.
I see that there are essentially 5 reasons a constant horn will sound with guardian mode,
1) Low oil pressure
2) RPM Overspeed
3) Overheat
4) Low sea pump pressure
5) Low gear lube
Oil level and pressure on oil gauge are fine, I’m not over speeding, engine temp is midrange no fluctuations, gear lube level is fine, and it’s not low pump pressure.
So, my question is what is causing constant horn with no indications as to why on my gauge? I’ve replaced sea pump pressure sender previously, my guess is to change out oil pressure and temp sending units for the heck of it (again though, gauge would have flashed either two of those if that were the case).
1) Low oil pressure
2) RPM Overspeed
3) Overheat
5) Low gear lube
