New Member with Mercruiser 470 problems
keithnpa42
I have been reading a lot of posts on here and it has been very helpful. Now I?m hoping to get to the bottom of my problems.
1986 mercruiser 470 3.7 170hp......
First time on the water, it ran great for about an hour. It then started to over heat and I had to shut it down. It got to about 200 to 225 degrees. I got towed in, but it started right back up. When I bought the boat I was told that the lower impeller had just been replaced.
I checked the upper circulating pump and it was in good shape. I back flushed the system including the heat exchanger and replaced the thermostat. I changed the oil and replaced the coolant. Engine ran great on land with ears on never braking 175 degrees.
I take the boat on the water and within a few minutes it starts to get hot, and then started to spit oil out of the dipstick. I lost all the oil. I got it back to the dock put more oil in and it would turn over but would not start.
I took it to my mechanic and he believes I got coolant in the oil probably due to the seals behind the circulating pump failing.
I am having him do a compression test, and I will be changing the seals
What else should I do, and/or be looking at? How the heck can I get this engine to just run and not continue to have problems? Any help would be greatly appreciated.
Thanks
xltier
Re: New Member with Mercruiser 470 problems
they are very problamatic,thats y merc dropped them.
45Auto
Don't trust what anyone tells you when you're buying a used vehicle. Check the impellor before you do anything else.
stonyloam
Most likely a blown/leaking head gasket. The compression test will tell. If you need to replace it use OEM Mercruiser gasket. Let us know how it turns out. Good luck.
CAPTKEV85
sounds like head gasket
JustJason
Check the diameter of the heat exchanger. If you have the old 3 inch one you need to upgrade it to a 4 inch one.
keithnpa42
well I got the compression test back and everything was fine with that. So Its change the seals first. I will look at the lower unit next if this does not fix the problem.
Thank you for all the advice and I will follow up after this weekend.
It does have the 4inch heat exchanger, but does anyone know how much coolant you should put in it? should you be able to see the coolant in the resevoir tank on top of the intake?
stonyloam
What were your compression numbers? The blowing oil out of the crankcase is still a mystery.
keithnpa42
I have now found out the problem. My coolant reservoir seal was bad and it was leaking coolant right into the engine. This in turn caused the oil to blow out. In addition I now have a knock in the engine. Per a qualified mechanic he believes that the coolant got into the engine and washed the bearings and that is where the knock is coming from. He then told me all the wonderful things that will/could go wrong even if I got that problem fixed. In other words this engine is a piece of s h i t and I should get rid of it as soon as possible. Any other advice out there? Does anyone want to buy a boat real cheap? Let me know.
Thank You
Keith
Showtime22
I just swapped out my blown 470 for a Merc 260. I bought a donor boat for 800 bucks with a good 350 and lifted it with a cherry picker I rented for 42 bucks a day. I then used the cherry picker to place the 470 block in the trash container. By swapping I gained an alternator system, power steering, and a motor that rips.
It's not a real hard swap but I do not recommend it unless the boat is at least an 8 out of 10. Mine is a 6. If you do decide to do a swap I will post a longer list of issues I dealt with in the swap.
keithnpa42
I am looking at a few options on an engine change out. Will a 165hp mercruiser straight 6 fit without any modifications to the boat? It is a front mount engine, but do you have to change the out drive? Is there any other issues that I should know about when changing it out?
Thanks,
Keith
boltonranger
Thank You
Keith
Keith that gasket can fail on different motors - it didn't fail because it was a 470.
What I mean is you could have had this happen with a different engine/boat.
The 470 is not a "bad" engine. Why not repair it?
Then you'll KNOW what you have instead of taking someone elses word.
How bad of a loss do you think you will take if you sell it?
-br
bigskiohio
what i have read the aluminum head is a problem with them and they problematic , my suggestion is dont buy one to find out if it is true or not.
boltonranger
Head is iron, not aluminum.
-br
Rocky_Road
-br
Agreed...the block is aluminum, and the head is iron. There are aluminum heads out there, but I have never heard of one being adapted to the marine engine.
Many people blame the head gasket problems on the differing metals used by Mercruiser....
whatsagm
Keep the 470, I have done all the up grades on mine. I love this engine. Good on gas and good power. I fixed the cam seal issues upgraded my charging system and heat exchanger.
The Begginer
What uprgrades do you speccifucally have ??
Scott06
Thanks but i dont need a block just wondering about the flaws of these 470s and what are the fixes
Assumed u needed to rebuild engine due to knock…
head gaskets prone to blow in minor overheat
cam drive water pump - cam snout wears from seals leaks af into oil needs speedi sleeve
alternator conversion kit needed when voltage regulator dies
you may face some parts nla due to age but there are several folks that successfully run theirs for years
