Krsowles
Thread starter- Joined
- Jul 17, 2019
- 37
I bought a 1998 Sea Ray 180 the other day, knowing it has sat 3-4 years. The previous owner is an acquaintance and respected in community but I had never dealt with him directly. Just prior to sitting, dealer had done pretty major service on it after testing compression, which was good (not written on receipt
). Steering and shift cables, bellows etc were all replaced. Owner ran it a couple times before end of season, winterized and stored. He tried to run it last summer, while his brother and family visiting on vacation and it ran but very slow acceleration. Would finally get to plane in approximately 30 seconds, but only to about 32 mph. He says it should be low 40s. It duplicated this on quick test drive before I purchased. I’ve found several threads about this and immediately think fuel system and carb work. I also found the distributor cap was badly corroded, so replaced it with an auto cap because I have to order marine stuff but wanted to see if that helped at all. I cleaned both fuel filters (only carb inlet one had any real junk in it but some seemed silver?), and confirmed fuel pump putting out fuel into a container (no pressure gauge avail.) and put back together. When I bought it, the previous owner launched the boat and took me out for a quick test drive to show me how boat was running. After I cleaned the filters etc and changed cap, it has gotten worse and I made a quick, lousy video of it running. I’m looking for opinions of running now because there seems to be a lot of noise in motor now. Could be some detonation type noise but exhaust sounds a lot louder as well. Is there something else going on here, in your opinion? My guy will look at it in a couple weeks but my mind won’t stop playing it over. Things I know:
Gunk in fuel filter, probably needs carb done as well as check gas tank
Water separator needs to be installed.
It’s getting fuel, but can’t confirm enough.
spark arrestor clean
Plugs looked pretty decent and uniform.
New auto cap and rotor don’t seem as good as old corroded cap. Old rotor broke but will wire brush and reinstall old cap for grins.
Do you think there may be something else going on as well? Any assistance greatly appreciated!
youtube.com
June 13, 2021
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
