timharper89
- Joined
- Jun 24, 2018
- 247
Or trim fluid. U checked fluid levels, yet????Just got my boat out of storage, and this is in my bilge. The color looks strange to me. Power steering?
Not sure how to check the trim fluidOr trim fluid. U checked fluid levels, yet????
Ayuh,.... The trim pump has a tank,....Not sure how to check the trim fluid
Thanks. I'll check this out next week. The lines commonly get holes in them? Or would the issue likely be at the connections?pump looks fairly clean, at least no leaks noticeable in the pics. does not rule out a leak in one of the lines though
seeing as how your p/s pump is nearly empty check the cooler, the low pressure lines attached to it are a common cause for p/s leaks
thisOr would the issue likely be at the connections?
That sounds like my kind of repair. Thanks I'll check it outthis
the cooler is on the low pressure side of the p/s system. the lines are held in place by hose clamps at the barb fittings on the cooler. it's not a rare occurrence for the lines to become brittle and split at the ends. repair in this situation requires removal of the leaking hose(s), cutting off the damaged portion and reinstalling the line
