Kola16
- Joined
- Jun 23, 2019
- 229
Considering repowering my boat due to the constant troubles my engine has had. My boat is a 1979 Wellcraft Suncruiser 225, which is the boat in my avatar. The boat is heavy for 22.75 ft. at roughly 5000 lbs. with gear and without main engine or gas. It has a 22° deadrise at the transom without a reverse chine. In other words it takes a little bit to get on plane with the carbed 350 Mercruiser in it. Once it is up it does okay though. Tops out at 41 mph with a 4-blade, but a higher top speed would be fun....
So my question is this...What would you choose, all things considered, if your boat was an offshore fishing boat on the West Coast with the average trip about 100 miles roundtrip? Hole-shot is something to keep in mind with big waves, but other factors play in too. And yes, I realize there is an F350 and a Verado 300, but I am looking at price of the two...
What would be the hole-shot difference between the 3? I'm assuming the 383 with the Bravo III would definitely be the best, but by how much? And what about the F300 vs. Verado 350 for hole-shot?
Specs:
383 MAG @ 3500 RPMs ~11.5 GPH; 1,100 lbs. ------ ~$20,000 (engine and bravo III drive)
Yamaha F300 @ 4500 RPMs ~15.3 GPH; 580 + 200 (bracket) = 780 lbs. --------- ~$30,000
Mercury Verado 350 @ 4500 RPMs ~15 GPH; 670 + 200 (bracket) = 870 lbs. ---- ~$29,000
To me, it looks like the 383 is the clear winner in all aspects minus 400 extra lbs. Any ideas on the top speed or cruising speed though vs. the others? What about reliability on the sterndrive vs. the outboards?
Any other thoughts and opinions are appreciated!
Specs:
