thirstymate
Thread starter- Joined
- May 22, 2009
- 5
Engine sn 0L686854
Transom an 0L867686
Drive Sn 0L790665
Short version of the long back story;
Bough the boat (2000 Glastron Gx205) a week ago. Not running, as is... 68 hours.
I worked near 5 years as an Avionics tech, now while I'm not the best, I know my way around schematics and testing equipment. While looking at the boat, it was easy to discern from the wiring diagrams I was able to find that the parts that were being thrown at it to get it running were symptoms and not the cause. The bad ECU was the cause. Got an ECU and the boat runs.
The root of the problem that I can discern is the storage tactics for the last 2 years, which was a tarp... In Maine. The mildew on the seats was extensive and the havoc that was set to the electrical systems remains in question. Either the mercruiser systems have a 20 year shelf life, or do not under any circumstances store a boat under a tarp where the temperature and humidity fluctuate rapidly.
So, smoked the ECU which is now resolved.i found an mefi3 for a 5.0L of the same year. Got lucky. Utilizing the technique from the cars I had in the 90's pre obdII, and this website, I was able to pull a code 23 and code 34. Tested the IAT sensor, which was just wide open, aka dead, and without a clear way to test the MAP/MAT sensor I just ordered one as well. So for the extent of this post, those codes are resolved. This brings me to the last odd ball. The warning horn. Key on engine off, I get one beep followers by two short beeps. Then the beep sequence of one beep every (approx, I haven't timed it) 10 seconds starts. Running or not it continues. The only mention of anything remotely like this I can find is a description of an "intermittent beep" from a low drive oil level. This boat has the drive oil monitor system in it with the aux reservoir. I just want to make sure I'm not missing something, that this math adds up. Is anyone aware of a scenario that would cause this audio warning pattern? I do have a Seloc manual, but I am a bit at odds with it as it's useful information seems to be a bit misplaced ( ECU pinout in the fuel section? ) And more pertinent information like oil quantity and quality seems to be non existent. But it has helped none the less.
If nothing else, thanks for posting what you folks have in regards to other issues, it has helped a bit in deciphering this puzzle.
Transom an 0L867686
Drive Sn 0L790665
