Still running hot, please help .
Pedro19
1995 Sea Ray 220 open bow with Mercruiser 5.7 carb Alpha 1 Gen II / 200 original hours in fresh water boat that is new to me this season.
> Test drive and 1st trip out on lake were pretty short trips and boat operated as should. I did not pay a lot of attention to temp, but I recall it running just shy of dead center just under the 50 degree mark.
> 2nd trip: - Noticed that it would get up to the 165-168 mark but seemed to cool down as I would increase RPM - Did not think much of it.
> 3rd trip: moving at idle speed in cover looking at some houses when boat overheated and alarm sounded. Initially I shut off engine, then I recall that it would cool off when increasing RPM so I started boat and increased RPM and it started to cool back down and w/in a few minutes It settled in at about 168 to 171 degrees. Boat was supposed to have just had the impeller replaced prior to purchasing the boat. All mechanics in my area are 4 to 6 weeks out so I was trying to tackle myself.
> Cleaned out thermostat housing and installed new 142 degree thermostat. Housing was full of crud but I cleaned it all out - No change.
> Went ahead and replaced complete impeller kit - Noted when I removed old impeller it looked bound up and had a couple of the blades pointed in the wrong direction. - Took back out on lake and still running at 168 - 171 degrees
< removed all 4 upper cooling hoses as well as the feed hoses and all are open.
> Have taken boat back to the lake twice and went on two long trips that were about an hour each and ran the boat at about 3200 to 3500 RPM consistently and the boat runs great but still running around 169 degrees It cools down just a couple of degrees at idle speed but pretty much has settled in between 168 and 171
> I noted when I installed the thermostat that Mercury shows you can install either the original 140 degree or a 160 degree. I chose the original 140 degree .
Questions: Where do I start next? Is it ok to run the boat like this until off season?
>Should I go ahead and remove the main water pump from the front of the engine and check that? Could a cracked head cause this condition? Should I try a 160 degree thermostat? What should I try next? Thanks
Find out if the gauge is accurate. Get an IR temp gun and measure the thermostat housing to see if gauge shows the same.
Yes, that's where the temp sender is at.
Also measure the exhaust manifolds and elbows to get a reference
Pedro19
Ok went to Oreilly Auto Parts and bought IR temp gun. Took boat out and ran her for a good full hour and still running right at 169 - 170 on gauge. I shot the top of the thermostat housing several times and it was around 144 to 145 every time. I shot the manifold on top of the engine and it was 150 both exhaust manifolds were between 140 -145 as well. Does this mean that I have a bad gauge? Thanks
nola mike
Or bad wiring. Increased resistance in that circuit will cause the gauge to read high. What's your voltmeter read? Either way, knowing your baseline is the important thing. Looks like your actual temp is where it's supposed to be
phillyg
I had the same problem. IR thermometer showed normal temps everywhere I checked. Changed out my temp sensor/sender, no change. Finally changed out the gauge and problem fixed.
Good, your overheat issue is fixed, now its a gauge/sender issue
Check your sender with a ohm meter and pan of water
Pedro19
Is the sender the one on the left or right side of my thermostat housing? Thanks for all the help by the way!!
Pedro19
I had the same problem. IR thermometer showed normal temps everywhere I checked. Changed out my temp sensor/sender, no change. Finally changed out the gauge and problem fixed. So yours was reading high as well?
Pedro19
There is one on each side of the thermostat housing that only has one wire attached.
dingbat
Ok, thanks!!! Makes sense. I will try the sender 1st as it is pretty cheap.
You would be best served to troubleshoot before buying parts.
Sending units typically fail outright. They either work or they don’t.
In the end it most likely will be the gauge or a corroded wire
Pedro19
OK, I will look into it a little further. There was a lot of corrosion inside of the thermostat housing. I may need to really clean the sensor and try that direction. Thanks again
