mlewis0113
- Joined
- Jul 29, 2020
- 16
Previous reapir failures strike again with my boat. I don't have a serial number as someone swapped in a Jasper reman engine into my Glastron that originally had a Volvo drive. I noticed when I was running wires for my stereo that my engine was covered in rubber dust. I found the belt shredded on one side.
Further inspection revealed that the belt was definitely not tracking straight and it appeared the power steering pulley was too far forward. I noticed the pulley wasn't pressed on all the way. I rented the tool and pressed it on until the front of the pulley hub was flush with the shaft. It still appears that the power steering pump is too far forward.
The guy I bought it from stated that he converted it to the serpentine system, but he's lied about numerous things so take that with a grain of salt.
My engine is definitely pre-vortec. All of the engines I've seen with serpentine systems are vortec headed engines. Are the mounting faces for the pulley brackets on the heads different between pre-vortec and vortec? Should I just attempt to swap back to the v-belt system? Photos were taken after I pressed the P/S pp pulley on completely. Any input is appreciated.
