1963 Evinrude 28 HP Speeditwin Hard Start (Woodruff key?)
Lowcash2012
HI All,
I recently purchased a 1963 Evinrude 28 HP Speeditwin. It is hard to pull the start cord, but when I take the plugs out it pulls really easy. Others have mentioned this is probably a mechanical problem of some sort. Could it be a bad woodruff key? I have attached pictures. I am very new to outboard repair, so any advice you can give would be appreciated. I don't know if that is a normal amount of key or if I need a new one.
Thanks,
Lowcash2012
F_R
key is ok. Wires need to be dressed so they don't rub on flywheel (but that isn't making it hard to pull)
oldboat1
Try spinning the flywheel clockwise by hand with the plugs out, then with the plugs in. Difference is compression when plugs are in place. (That is, unless you feel a metal to metal obstruction.)
Nothing to do with the key.-----Electric start should be easy to find for that motor.----Your location ?
They are a handful to pull over on a stand.---Easier to do clamped on a boat.----I merely tried to help by suggesting the electric start option !
Lowcash2012
So at first I couldnt pull it at all, finally got it to where it would pull well enough that I could perform a compression test. I just replaced the coils but when i tighten down the nut on top the entire ignition plate moves and then stops and I cant move it any further. When i take the flywheel off the crank turns with a socket and just the nut.
Lowcash2012
Gotchya, thanks. Right now I can turn the flywheel a bit but then it seems to pull the ignition plate along with it. Then it stops completely.
Remove flywheel with puller ( 3 bolts 1/4-20NC ) perhaps coils are not adjusted properly.---There is a factory tool to set them in the correct spot.----Or visit ----leroysramblings----For info on that simple magneto.
