kramerpage
- Joined
- Jul 26, 2010
- 447
I removed mercruiser 3.0L motor and outdrive to have transom welded where it meets the bottom by drain plug.
Re installed motor and cannot get it aligned. I did not move the nuts on the front mount which is down all the way.
If I loosen the rear mount bolts I can almost get it right.
My question is can the rear mount lock washer or springs get worn out and make the rear sit too low?
Picture of front mount adjusted all the way down.
Picture of motor.
Thanks
Picture of motor.
Thanks
