bluestreak21
Thread starter- Joined
- Jul 19, 2011
- 9
2011 Volvo Penta 5.0 GXIC-P EFI,CAT EXH. Helping a friend out with his boat and having trouble finding much regarding the thermostat housing on the riser of exhaust manifold(Housing is heat control for cat). Engine started with overheat alarm, gauge seemed to be accurate. I went to the lake, started it, temp slowly climbed like normal. When the engine thermostat opened, a unfamiliar sound started coming from the starboard side exhaust manifold. Sounded like a pressured release, it lasted about 6-7 seconds then alarm when off, gauge did not react. Took engine t-stat off, tested fine,everything normal. I have the part on order, as it seems parts inside the housing are not serviceable.
My thought is the t-stat inside the starboard housing has failed and the exhaust is backflowing in the cooling system.
Wondering if anyone was experience with this exhaust thermostat system?
Thanks,
Pat
Thanks,
Pat
