Easy to move the drive one side by hand from the outside
Kubaat3lover
Its Alpha One Gen 2, Boat on a trailer, Ive noticed that I can pull the drive easily to the left by hand but to the right it doesnt move, is that correct?
steering wheel works just fine
achris
More fish than mountain goat
If I don't try to move it too fast, I can get mine to go all the way across. If I push it quickly, it locks up.
Kubaat3lover
I mean the play, slack from left to right or up-down when shaking the drive
achris
ok, that's a different issue. indicates worn pins (upper and lower swivel shafts). The amount I'd tolerate would be between 0.000" and 0.000". Outside that spec and I'd be pulling it all apart and fixing the problem. (but that's just me, I'm a bit anal. I took my engine out about 9 times to fix an oil leak most people wouldn't have even noticed. 🤦 )
Kubaat3lover
I read about That, front seal, oil pan?
Im also freak about this.. :))
