We have had 3 impeller failures over the last few seasons. This seemed to start after we had the gimbal ring replaced. We did the impeller twice with new housings and after maybe an hour of use it started overheating again and acting as if the impeller is out again.
We hooked up a clear tube between the inlet and impeller and noticed bubbles coming in from the sea water intake. Would some air getting into the system cause impeller failures? What could cause air getting in?
We have a mercruiser 350 mag with bravo 3 outdrive. 2000 Cobalt 206
