Jmcconnell
Thread starter- Joined
- Jun 29, 2021
- 8
Hello, first time post. Thanks for any help in advance. I have a mercruiser 3.0 that I have completely restored.(first timer) I have everything working great except the shift interrupter switch. Engine had old roller switch which which I have replaced with the newer button style. Had to get new shift cable mount plate bc of the old rollers are hard to find new. Long story short. When I discount the new switch the engine starts and shifts fine(out of water). However when I wire up new switch I get no spark. If I press in the switch while someone else starts engine it fires up no problem... I am perplexed as to what is going on. I have looked at wiring diagram and it shows the green white wire leaving the shift interrupter switch and running to the distributor. However my distributor only has a black wire running from it to the negative on the coil. I am missing something...thanks again.
