Nextelbuddy
- Joined
- May 4, 2020
- 163
So I just finished reassembling my upper and lower units for the outdrive alpha 1 Gen 2.
I replaced the water pump impeller kit, input shaft carrier assembly underneath the water pump, and I pressure test the entire system at 12 psi for 20 minutes with zero pressure loss after everything was assembled.
I checked my box of OEM mercruiser parts that I ordered and in that box was a brand new shift shaft carrier assembly that I forgot I bought.
I have the original shift shaft seal and assembly it is white in color currently installed, someone saw it and said that I should change that out because it's quite old and original. Again I had zero pressure loss in my pressure test with the original shift shaft carrier assembly. Sometimes I feel like it's one of those if it ain't broke don't fix it but on the other hand I have the outdrive off and I can pull it back apart and just replace it it's already there.
The main thing is holding me back is that I can't find a good DIY article or a YouTube video that shows that carrier assembly for the shift shaft...
And what forum posts I do find on the iboat forum when somebody asks how to do it other people mention be very careful when you pull it off because of something shifts at a place you're screwed.... I can only imagine how difficult it is to pull an assembly off of a shaft carefully and straight up when it's the original part and never been removed before so that adds anxiety to the fire.
In all honesty how hard of a job and how scary Is it replacing that carrier assembly for the shift shaft?
