Yeah, moving the filler isnt the worst thing in the world. Right now its in a bad spot, not easy to get to from the side or the windshield opening. At least when I move it i will have an easier time filling it up. For now though I have it in and will go through that headache in the off season. I just got used to not being itchy, sticky, and smelling like resinGotcha - that's a bummer.
I have a buddy that owns an exhaust shop I am going to have him bend me some up that will work. None of the stores around me had anything outside of 90s and 45s. I am to impatient for ordering anything.I'm not getting a mental picture of what you're describing, but there must be a way.
I found aluminum elbows from 30 to 120 degrees. Mine has a 120.View attachment 344478
I was going to go that route but I found the lifter for 8 bucks and on the inline 4 they are an easy swap just need to remove the distributor the push rod and a cover on the side of the block.Collapsed lifters often respond well to additives like Rislone. You draw out some oil and replace it with the additive of your choice and run it awhile.
There are several such products.
Yup.. keep at it! Good to have motor skills. In that dept I'm a -9Well, I finally got around to putting that lifter in, and it did the trick!!! Ran great got the valve lash, timing, and idle dialed in. Then I noticed it leaking from the push rod cover. Took the distributor back out to get to the plate and realized that it kept moving on me when I go to install it because I have to slide it behind the fuel line. Put a bead of gasket maker on the front and back of the gasket so it does not move on me. Now waiting for that to cure and fire it back up and tune it back in.
Rumor has it I will have the week of the 16th off (got to love the auto industry) so hopefully she will be splashed then!
Luckily I was a master mechanic (let my certifications expire) Went with a stern drive due to the fact that it is basically a car motor and I could work on it. Not to much experience with outboards though. I have maintained my 9.9 so I never really needed to do anything to it. 99% of working on a motor is get to the part, change it, then put back together how you found it. Not always as easy as it sounds though.Yup.. keep at it! Good to have motor skills. In that dept I'm a -9
