(Still a new boat owner) So I took the 1999 Bayliner Capri out for a test run after dewinterizing it...(btw it ran fine the year prior and located in the southeast)...was on the water for a good 15 minutes waiting on my wife to park the trailer with no issues. I picked her up and was cruising out past the no wake zone and I looked over at the engine to see a chocolate milk substance coming out of the top of the two hoses that lead to the carburetor...of course I docked and loaded it up to the trailer. So after some research, I believe that I might need to redo the head gaskets...and of note, I know I need a new thermostat from troubleshooting. There is water in the oil chamber where you fill it and where the dip stick is. And there was nothing abnormal from the drain plugs. Looking for some guidance before doing a lot of work...
Again the milky substance was coming up and out towards the carburetor and not out of the carburetor.
My thinking is change the head gaskets...observe while it's open...and change the oil...and I'm putting a new thermostat in.
