Mercruiser 4.3 Oil Pan Drain Fitting Size
AMMO DAWG
Got a slight leak where the dip stick and drain hose screw into the oil pan on my 4.3. Was getting ready to replace the two gaskets and noticed the pan threads don't look so hot, anybody know what thread size the pan uses, like to try and see if I can run a tap and clean them up, thanks
doubt its the threads. however should be 1/2-20 on early pans and metric on later pans
AMMO DAWG
It's leaking where it attaches to the pan (see arrow), I'm hesitant to torque it tighter since the threads look like they might be buggerd up. My thought was to first see if I could clean them up with a tap. I ordered new gaskets so I have some time to mess with the threads.
wshekar
It's leaking where it attaches to the pan (see arrow), I'm hesitant to torque it tighter since the threads look like they might be buggerd up. Mt thought was o first see if I could clean them up with a tap. I ordered new gaskets so I have some time mess with the threads.
That pan is likely cast iron and the fitting is brass. Tighten the fitting too much and it will break. I went through 2 fittings because the torque in the manual was wrong. Probably just replace the gasket and tighten hand tight.
AMMO DAWG
That's not good, did it break off in the pan? How did you extract it after it broke?
Fun Times
Your picture seems different than the one i located...To be safe in searching, what is your serial number?
wshekar
I torque slow. I felt it give a bit before I hit the number but it hadn't sheared off so I was able to back it out. I thought the first one had a defect but when the second broke I knew torque was too high.
That brass fitting should never be able to damage those threads.
AMMO DAWG
It was a barn find engine I rebuilt for a repower, I do know it came off a 1999 boat. Unfortunately the numbers were gone when I got the engine. The picture I posted is what is attached to the pan, a drain hose dip stick tube fitting.
Fun Times
Buy both sizes listed / mentioned and you should be good when ready. ;)
810-809981SCREW, Drain (12MM) ((M12 x 1.75mm))NLA
= Aluminum
1010-49956SCREW, Drain (1/2-20)ACT
= Stamped Steel
