OMC Sterndrive 165; 1974 Winner "Minikai"
markdeborde
I'm new here ..... this is my first post.
I'm 61 years old and bought my first boat......1974 Winner "Minikai". And I'm already working on the OMC Sterndrive 165. I need to give a "Shout-Out" to Howard Sterndrive:
Thank you Howard ! 🙂 I read a post you made back in 2011 that helped me GREATLY with my problem with the tilt motor/shaft/clutch/quadrant gear/ect..... had the wife give me a hand and I'm moving forward with getting my first boat in the water for the first time ! Again THANK you for that post !
Respectfully,
markdeborde
kenny nunez
If they are stripped then the stringers need to be replaced. The engine and drive will need to be removed.
markdeborde
I checked all (12) bolts. Its got an Inline 6 cylinder with power trim. Each of the 4 engine mounts have 3 bolts. All were tight..... I wrenched each one hard enough to turn the bolt some..... no problems with the stringers that the engine mounts to ! 🙏🏻 Thanks for telling me to check that ! 👍
froggy1150
With a boat that old there is rot. Just a matter how much. Need to do some test holes. Start with reading all the stickys
