trikeman72
Thread starter- Joined
- Aug 24, 2012
- 58
I have to be missing power at the middle button coz I’m not sure using the middle button matters as far as making it go down ya know?So D is not getting power, that is why your drive isn't working for up. Look at Achris' wiring diagram in post in #9. Follow that wire connected to D, it runs back to junction where it splits to two wires, one goes to the trim limit switch, and the other runs to the top switch of the 3 button control at the dash/helm.
On the back of the middle button of the 3 button control, is a purple wire and red wire. Red should have 12 volts all time, it is jumped off the red wire on the bottom switch which is working for you. Do you have power on the red wire on the middle switch?
If So.... Purple will get 12 volts when the middle switch is turned on. Does it?
When the purple wire gets 12 volts, it should also power the purple wire on the top button.
With both the middle and top buttons both on, the blue wire on the top button should have power and so should your terminal "D" on your solenoid, and your motor should be powered up.
gonna see if I can get under dash to grab some testing on the switch buttons now
