406Maverick
Thread starter- Joined
- Mar 11, 2021
- 46
Hello everyone! I have finally had a chance to get the boat out on the water a few times this spring, and so far she has been running like a champ- almost. The only issue is a short "bog" anytime I go WOT. Doesn't matter if it's from a standstill or if I'm cruising. If I go WOT it bogs for maybe .5-1 second and then takes off. Here is how I have it set up now-
01 VP 5.0
Edelbrock 1409- all stock carb tuning (as it came in the box)
Timing @ 10 degrees base
Accelerator pump set to top hole (richest)
91 octane ethanol free fuel
I have thought about trying the upgrade the accelerator pump spring, but I am not sure which one would be stiffer- maybe a 1468..? Is it possible I should leaner on the accelerator pump? thanks!
01 VP 5.0
