jonny rotten
- Joined
- Jan 8, 2012
- 380
Put new gimbal bearing in the freezer overnight before installing. It shrinks and makes a noticeable difference installing the new bearing. And believe me its a tight fit.Sorry for the late response - thanks for the tips and video!
I've already ran into that shift arm set screw - wouldn't budge. In order to get the bell housing off I ended up sawzalling through the shift cable - definitely overkill but it worked. I'll be dealing with that shift arm towards the end of the rebuild. I think I'll probably do that shift cable last.
After much persuasion from the slide hammer I was able to get the old gimbal bearing out. That was much harder than I expected. I don't think anything back there has been touched in the last 35 years.
I'm slowly but surely moving forward - have to wait for parts anyway so I'll keep you guys apprised. I'm most definitely going to need more advice / tips in the future.
There are you tube videos on removing the shift lever. I believe you take a chisel and hammer and split the lever in 2. That screw will never come loose. Then use a bolt and nuts to crank off the shaft
Soak the crap out of the lower shift cable nut with PB Baster on the bellhousing for a day or two. Mine was crusted in there big time and stripping it seems like a massive headache you don't need
