mturner125
Thread starter- Joined
- Sep 1, 2020
- 16
All,
A couple weeks back I noticed that the voltage meter on my dash had moved up to the 15-17 range, sometimes approaching 18v, with the motor running. After topping off the battery water, I headed back out on the boat this morning. Battery voltage was right at 12.7 after topping off the water. Everything worked as it should today but the meter still measured very high. Voltage at the battery stayed in the 14.5-14.75 range while running. I also noted that I was getting a reading of about 12.7 on the terminals at the voltage meter while running, which I thought was a bit odd.
Any ideas? I was surprised that the voltage on the terminals on the back of the voltage meter showed 12.7 while the meter was reading 16+. Does this point to a bad meter or maybe a bad voltage regulator?
Thanks in advance
Thanks in advance
