Djunegarcia
Thread starter- Joined
- Jul 24, 2021
- 14
Hi all..I have a Mercury Mercruiser Alpha One Gen II outdrive with a V6 4.3L engine. Recently took the boat out and thought I spun a hub as my prop stopped rotating but engine was still revving. Was towed in now my boat is in my garage. Upon disassembling the Alpha One outdrive I started to remove the upper gear box case. Gear lube “Oil” was not in the upper gear box and gears were sheared smooth. I’ve purchased new upper gears and began a deep cleaning to remove any and all metal shavings/dirt/grime. I am now at a stand still simply because the gear/bearing/ shaft that runs vertical “Up and down” which I believe is called the driven shaft has both a bearing and gear that seems to be pressed on the shaft. Anyone know how I can remove the old gear/bearing off old shaft and put new gear/bearing on the same shaft??
