Trigger help
Sea rayder1995
Does anyone know the proper way to adjust a trigger on a 1995 sea rayder f16 with the 120 mercury sport jet engine?
Force motor? If so, you might repost in the Mercury/Force forum.
There should be no need to adjust the trigger.-----What is this motor doing / not doing ?
Sea rayder1995
I've gotten it on trade and it stopped getting spark I've replaced the trigger stator switchbox coils wires and plugs and still not getting spark, I am getting voltage to my switchbox but I don't think the trigger is sending the signal to let the voltage go to the coils.
Sea rayder1995
I got a 1995 sea rayder f16 with a 120 mercury sport jet engine inboard in it, it stopped getting spark so I've replace trigger stator switchbox coils wires and plugs I am now getting voltage to the box but I do not believe the trigger is sending signal to release the voltage to the coils and I am wondering if anyone knows the proper way to adjust the trigger on this, please help any and all information will be appreciated, thank you in advance.
jbcurt00
Please dont start multiple topics about the same subject
Merged
Poormansboating
Don't think trigger needs adjusted as that has more to do with the Timing I believe. Sounds like a bad connection somewhere to me.
jerryjerry05
Look at "static timing" if you want to mess with the trigger?? but we need to know what ignition system you have??
But the trigger's probably not the problem.
No spark: flywheel key, bad stator, bad pack, ?
Post pics of the ignition system? you could have 3-4 different systems, one system even has a rev limit module, let us know, Model# Serial # pics???
